BSP and Device Driver Development Guide
RTEMS uses the GNU automake and GNU autoconf automatic
configuration package. Consequently, there are a number of
automatically generated files in each directory in the RTEMS
source tree. The bootstrap script found in the top level
directory of the RTEMS source tree is executed to produce the
automatically generated files. That script must be run from
a directory with a configure.ac file in it. The bootstrap
command is usually invoked in one of the following manners:
bootstrap to regenerate all files that are generated by
autoconf and automake.
bootstrap -c to remove all files generated by autoconf and
automake.
bootstrap -p to regenerate preinstall.am files.
There is a file named Makefile.am in each directory of
a BSP. This file is used by automake to produce the file named
Makefile.in which is also found in each directory of a BSP.
When modifying a Makefile.am, you can probably find examples of
anything you need to do in one of the BSPs.
The configure process specializes the Makefile.in files at the time that RTEMS
is configured for a specific development host and target. Makefiles
are automatically generated from the Makefile.in files. It is
necessary for the BSP developer to provide the Makefile.am
files and generate the Makefile.in files. Most of the
time, it is possible to copy the Makefile.am from another
similar directory and edit it.
The Makefile files generated are processed when configuring
and building RTEMS for a given BSP.
The BSP developer is responsible for generating Makefile.am
files which properly build all the files associated with their BSP.
Most BSPs will only have a single Makefile.am which details
the set of source files to build to compose the BSP support library
along with the set of include files that are to be installed.
This single Makefile.am at the top of the BSP tree specifies
the set of header files to install. This fragment from the SPARC/ERC32
BSP results in four header files being installed.
include_HEADERS = include/bsp.h include_HEADERS += include/tm27.h include_HEADERS += include/erc32.h include_HEADERS += include/coverhd.h
When adding new include files, you will be adding to the set of
include_HEADERS. When you finish editing the Makefile.am
file, do not forget to run bootstrap -p to regenerate the
preinstall.am.
The Makefile.am also specifies which source files to build.
By convention, logical components within the BSP each assign their
source files to a unique variable. These variables which define
the source files are collected into a single variable which instructs
the GNU autotools that we are building libbsp.a. This fragment
from the SPARC/ERC32 BSP shows how the startup related, miscellaneous
support code, and the console device driver source is managed
in the Makefile.am.
startup_SOURCES = ../../sparc/shared/bspclean.c ../../shared/bsplibc.c \
../../shared/bsppredriverhook.c \
../../shared/bsppost.c ../../sparc/shared/bspstart.c \
../../shared/bootcard.c ../../shared/sbrk.c startup/setvec.c \
startup/spurious.c startup/erc32mec.c startup/boardinit.S
clock_SOURCES = clock/ckinit.c
noinst_LIBRARIES = libbsp.a
libbsp_a_SOURCES = $(startup_SOURCES) $(console_SOURCES) ...
When adding new files to an existing directory, do not forget to add
the new files to the list of files to be built in the corresponding
XXX_SOURCES variable in the Makefile.am and run
bootstrap.
Some BSPs use code that is built in libcpu. If you BSP does
this, then you will need to make sure the objects are pulled into your
BSP library. The following from the SPARC/ERC32 BSP pulls in the cache,
register window management and system call support code from the directory
corresponding to its RTEMS_CPU model.
libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/cache.rel \
../../../libcpu/@RTEMS_CPU@/reg_win.rel \
../../../libcpu/@RTEMS_CPU@/syscall.rel
NOTE: The Makefile.am files are ONLY processed by
bootstrap and the resulting Makefile.in files are only
processed during the configure process of a RTEMS build. Therefore,
when developing a BSP and adding a new file to a Makefile.am,
the already generated Makefile will not automatically
include the new references unless you configured RTEMS with the
--enable-maintainer-mode option. Otherwise, the new file not
being be taken into account!
