Any real-time executive must provide a mechanism for quick response to externally generated interrupts to satisfy the critical time constraints of the application. The interrupt manager provides this mechanism for RTEMS. This manager permits quick interrupt response times by providing the critical ability to alter task execution which allows a task to be preempted upon exit from an ISR. The interrupt manager includes the following directive:
rtems.interrupt_catch - Establish an ISR
rtems.interrupt_disable - Disable Interrupts
rtems.interrupt_enable - Enable Interrupts
rtems.interrupt_flash - Flash Interrupt
rtems.interrupt_is_in_progress - Is an ISR in Progress
