Getting Started with GNAT/RTEMS
In order to insure that the cross-compiler is invoking the correct
subprograms (like as and ld), one can test assemble
a small program. When in verbose mode, gcc prints out information
showing where it found the subprograms it invokes. In a temporary
working directory, place the following function in a file named f.c:
int f( int x )
return x + 1;
Then assemble the file using a command similar to the following:
m68k-rtems-gcc -v -S f.c
Where m68k-rtems-gcc should be changed to match the installed
name of your cross compiler. The result of this command will be
a sequence of output showing where the cross-compiler searched for
and found its subcomponents. Verify that these paths correspond
to your <INSTALL_POINT>.
Look at the created file f.s and verify that it is in fact
for your target processor.
Then try to compile the file f.c directly to object code
using a command like the following:
m68k-rtems-gcc -v -c f.c
If this produces messages that indicate the assembly code is
not valid, then it is likely that you have fallen victim to
one of the problems described in
Error Message Indicates Invalid Option to Assembler
Don't feel bad about this, one of the most common installation errors
is for the cross-compiler not to be able to find the cross assembler
and default to using the native as. This can result in very confusing
error messages.
