RTEMS POSIX 1003.1 Compliance Guide
sigset_t, Type, Implemented SIG_DFL, Constant, Implemented SIG_IGN, Constant, Implemented SIG_ERR, Constant, Implemented SIGABRT, Constant, Implemented SIGALRM, Constant, Implemented SIGFPE, Constant, Implemented SIGHUP, Constant, Implemented SIGILL, Constant, Implemented SIGINT, Constant, Implemented SIGKILL, Constant, Implemented SIGPIPE, Constant, Implemented SIGQUIT, Constant, Implemented SIGSEGV, Constant, Implemented SIGTERM, Constant, Implemented SIGUSR1, Constant, Implemented SIGUSR2, Constant, Implemented SIGCHLD, Constant, Unimplemented SIGCONT, Constant, Unimplemented SIGSTOP, Constant, Unimplemented SIGTSTP, Constant, Unimplemented SIGTTIN, Constant, Unimplemented SIGTTOU, Constant, Unimplemented SIGBUS, Constant, Implemented SIGRTMIN, Constant, Implemented SIGRTMAX, Constant, Implemented
NOTE: SIG_ERR is technically an extension to the C Library which is not documented anywhere else according to the index.
