BSP and Device Driver Development Guide
Some BSPs provide additional tools that aid in using the target board. These tools run on the development host and are built as part of building the BSP. Most common is a script to automate running the RTEMS Test Suites on the BSP. Examples of this include:
powerpc/psim includes scripts to ease use of the simulator
m68k/mvme162 includes a utility to download across the
VMEbus into target memory if the host is a VMEbus board in the same
chasis.
unix/posix includes scripts to run the tests automatically
on this BSP.
