clearerr - Clear file or stream error indicator
fclose - Close a file
feof - Test for end of file
ferror - Test whether read/write error has occurred
fflush - Flush buffered file output
fgetc - Get a character from a file or stream
fgetpos - Record position in a stream or file
fgets - Get character string from a file or stream
fiprintf - Write formatted output to file (integer only)
fopen - Open a file
fdopen - Turn an open file into a stream
fputc - Write a character on a stream or file
fputs - Write a character string in a file or stream
fread - Read array elements from a file
freopen - Open a file using an existing file descriptor
fseek - Set file position
fsetpos - Restore position of a stream or file
ftell - Return position in a stream or file
fwrite - Write array elements from memory to a file or stream
getc - Get a character from a file or stream (macro)
getchar - Get a character from standard input (macro)
gets - Get character string from standard input (obsolete)
iprintf - Write formatted output (integer only)
mktemp - Generate unused file name
perror - Print an error message on standard error
putc - Write a character on a stream or file (macro)
putchar - Write a character on standard output (macro)
puts - Write a character string on standard output
remove - Delete a file's name
rename - Rename a file
rewind - Reinitialize a file or stream
setbuf - Specify full buffering for a file or stream
setvbuf - Specify buffering for a file or stream
siprintf - Write formatted output (integer only)
scanf - Scan and format input
tmpfile - Create a temporary file
tmpnam - Generate name for a temporary file
vprintf - Format variable argument list
