abort - Abnormal termination of a program
abs - Integer absolute value (magnitude)
assert - Macro for Debugging Diagnostics
atexit - Request execution of functions at program exit
atof - String to double or float
atoi - String to integer
bsearch - Binary search
calloc - Allocate space for arrays
div - Divide two integers
ecvtbuf - Double or float to string of digits
ecvt - Double or float to string of digits (malloc result)
__env_lock - Lock environment list for getenv and setenv
gvcvt - Format double or float as string
exit - End program execution
getenv - Look up environment variable
labs - Long integer absolute value (magnitude)
ldiv - Divide two long integers
malloc - Allocate memory
realloc - Reallocate memory
free - Free previously allocated memory
mallinfo - Get information about allocated memory
__malloc_lock - Lock memory pool for malloc and free
mbstowcs - Minimal multibyte string to wide string converter
mblen - Minimal multibyte length
mbtowc - Minimal multibyte to wide character converter
qsort - Sort an array
rand - Pseudo-random numbers
strtod - String to double or float
strtol - String to long
strtoul - String to unsigned long
system - Execute command string
wcstombs - Minimal wide string to multibyte string converter
wctomb - Minimal wide character to multibyte converter
