int sem_trywait( sem_t *sem );
sem
argument does not refewr to a valid semaphore
This function attempts to lock a semaphore specified by sem
. If the
semaphore is available, then the semaphore is locked (i.e., the semaphore
value is decremented) and the function returns a value of 0. The semaphore
remains locked until released by a sem_post()
call. If the semaphore
is unavailable (i.e., the semaphore value is zero), then the function will
return a value of -1 immediately and set errno
to EAGAIN.
If the call is unsuccessful, then the function returns -1 and sets
errno
to the appropriate error code.
Multiprocessing is not supported in this implementation.
