void rtems_chain_initialize( rtems_chain_control *the_chain, void *starting_address, size_t number_nodes, size_t node_size )
Returns nothing.
This function take in a pointer to a chain control and initializes it
to contain a set of chain nodes. The chain will contain number_nodes
chain nodes from the memory pointed to by start_address. Each node
is assumed to be node_size bytes.
This call will discard any nodes on the chain.
This call does NOT inititialize any user data on each node.
