bool rtems_interrupt_is_in_progress( void );
NONE
This directive returns TRUE if the processor is currently
servicing an interrupt and FALSE otherwise. A return value
of TRUE indicates that the caller is an interrupt service
routine, NOT a task. The directives available to an interrupt
service routine are restricted.
This directive will not cause the calling task to be preempted.
