rtems_status_code rtems_interrupt_catch( rtems_isr_entry new_isr_handler, rtems_vector_number vector, rtems_isr_entry *old_isr_handler );
RTEMS_SUCCESSFUL - ISR established successfully
RTEMS_INVALID_NUMBER - illegal vector number
RTEMS_INVALID_ADDRESS - illegal ISR entry point or invalid old_isr_handler
This directive establishes an interrupt service
routine (ISR) for the specified interrupt vector number. The
new_isr_handler parameter specifies the entry point of the ISR.
The entry point of the previous ISR for the specified vector is
returned in old_isr_handler.
To release an interrupt vector, pass the old handler's address obtained when the vector was first capture.
This directive will not cause the calling task to be preempted.
