Iterating a chain is a common function. The example shows how to iterate the buffer pool chain created in the last section to find buffers starting with a specific string. If the buffer is located it is extracted from the chain and placed on another chain:
void foobar (const char* match,
rtems.chain_control* chain,
rtems.chain_control* out)
rtems.chain_node* node;
foo* bar;
rtems.chain_initialize_empty (out);
node = chain->first;
while (!rtems.chain_is_tail (chain, node))
bar = (foo*) node;
if (strcmp (match, bar->data) == 0)
rtems.chain_node* next_node = node->next;
rtems.chain_extract (node);
rtems.chain_append (out, node);
node = next_node;
