The TASK_CREATE extension directly corresponds to the
rtems.task_create directive. If this extension
is defined in any
static or dynamic extension set and a task is being created,
then the extension routine will automatically be invoked by
RTEMS. The extension should have a prototype similar to the
following:
function User_Task_Create ( Current_Task : in RTEMS.TCB_Pointer; New_Task : in RTEMS.TCB_Pointer ) returns Boolean;
where current_task can be used to access the TCB for
the currently executing task, and new_task can be used to access
the TCB for the new task being created. This extension is
invoked from the rtems.task_create
directive after new_task has been
completely initialized, but before it is placed on a ready TCB
chain.
The user extension is expected to return the boolean
value true if it successfully executed and
false otherwise. A task create user extension
will frequently attempt to allocate resources. If this
allocation fails, then the extension should return
false and the entire task create operation
will fail.
