procedure Task_Set_Note ( ID : in RTEMS.ID; Notepad : in RTEMS.Notepad_Index; Note : in RTEMS.Unsigned32; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - task's note set successfully
RTEMS.INVALID_ID - invalid task id
RTEMS.INVALID_NUMBER - invalid notepad location
This directive sets the notepad entry for the task specified by id to the value note.
If id is set to RTEMS.SELF, the calling
task accesses its own notepad locations.
This directive will not cause the running task to be preempted.
The sixteen notepad locations can be accessed using the constants
RTEMS.NOTEPAD_0 through RTEMS.NOTEPAD_15.
Setting a notepad location of a global task which does not reside on the local node will generate a request to the remote node to set the specified notepad entry.
