procedure Task_Suspend ( ID : in RTEMS.ID; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - task restarted successfully
RTEMS.INVALID_ID - task id invalid
RTEMS.ALREADY_SUSPENDED - task already suspended
This directive suspends the task specified by id from further
execution by placing it in the suspended state. This state is
additive to any other blocked state that the task may already be
in. The task will not execute again until another task issues
the rtems.task_resume
directive for this task and any blocked state
has been removed.
The requesting task can suspend itself by specifying RTEMS.SELF as id.
In this case, the task will be suspended and a successful
return code will be returned when the task is resumed.
Suspending a global task which does not reside on the local node will generate a request to the remote node to suspend the specified task.
If the task specified by id is already suspended, then the
RTEMS.ALREADY_SUSPENDED status code is returned.
