Getting Started with GNAT/RTEMS
After the bit_ada
script has been modified to reflect the
local installation, the modified bit_ada
script is run
using the following sequence:
cd tools ./bit_ada <target configuration>
Where <target configuration> is one of the following:
NOTE: The above list of target configurations is the list of RTEMS supported targets. Only a subset of these have been tested with GNAT/RTEMS. For more information, contact your GNAT/RTEMS representative.
The build process can take a while to complete. Many users find it handy to run the build process in the background, capture the output in a file, and monitor the output. This can be done as follows:
./bit_ada <target configuration> >bit.log 2>&1 & tail -f bit.log
If no errors are encountered, the bit_ada
script will conclude by
printing messages similar to the following:
The src and build-i386-tools subdirectory may now be removed. Started: Fri Apr 10 10:14:07 CDT 1998 Finished: Fri Apr 10 12:01:33 CDT 1998
If the bit_ada
script successfully completes, then the
GNU C/C++ cross compilation tools are installed.
If the bit_ada
script does not successfully complete, then investigation
will be required to determine the source of the error.
