Starting FTPD is done with a call to rtems_initialize_ftpd().
The configuration structure must be provided in the application
source code. Example hooks structure and configuration structure
folllow.
struct rtems_ftpd_hook ftp_hooks[] =
{"untar", Untar_FromMemory},
{NULL, NULL}
struct rtems_ftpd_configuration rtems_ftpd_configuration =
40, /* FTPD task priority */
512*1024, /* Maximum hook 'file' size */
0, /* Use default port */
ftp_hooks /* Local ftp hooks */
Specifying 0 for the well-known port causes FTPD to use the UNIX standard FTPD port (21).
