The network configuration is specified by declaring
and initializing the rtems_bsdnet_config
structure.
struct rtems_bsdnet_config {
* This entry points to the head of the ifconfig chain.
struct rtems_bsdnet_ifconfig *ifconfig;
* This entry should be rtems_bsdnet_do_bootp if BOOTP
* is being used to configure the network, and NULL
* if BOOTP is not being used.
void (*bootp)(void);
* The remaining items can be initialized to 0, in
* which case the default value will be used.
rtems_task_priority network_task_priority; /* 100 */
unsigned long mbuf_bytecount; /* 64 kbytes */
unsigned long mbuf_cluster_bytecount; /* 128 kbytes */
char *hostname; /* BOOTP */
char *domainname; /* BOOTP */
char *gateway; /* BOOTP */
char *log_host; /* BOOTP */
char *name_server[3]; /* BOOTP */
char *ntp_server[3]; /* BOOTP */
unsigned long sb_efficiency; /* 2 */
/* UDP TX: 9216 bytes */
unsigned long udp_tx_buf_size;
/* UDP RX: 40 * (1024 + sizeof(struct sockaddr_in)) */
unsigned long udp_rx_buf_size;
/* TCP TX: 16 * 1024 bytes */
unsigned long tcp_tx_buf_size;
unsigned long tcp_rx_buf_size;
The structure entries are described in the following table. If your application uses BOOTP/DHCP to obtain network configuration information and if you are happy with the default values described below, you need to provide only the first two entries in this structure.
void (*bootp)(void)
if your application will use BOOTP/DHCP
to obtain network configuration information.
It should be set to NULL
if your application does not use BOOTP/DHCP.
int network_task_priority
char *hostname
NULL the value
may be obtained from a BOOTP/DHCP server.
char *domainname
char *gateway
129.128.4.1) form.
char *log_host
syslog messages
will be sent.
char *ntp_server[3]
8 to 2.
The user should also be aware of the SO_SNDBUF and SO_RCVBUF
IO control operations. These can be used to specify the
send and receive buffer sizes for a specific socket. There
is no standard IO control to change the sb_efficiency factor.
The sb_efficiency parameter is a buffering factor used
in the implementation of the TCP/IP stack. The default is 2
which indicates double buffering. When allocating memory for each
socket, this number is multiplied by the buffer sizes for that socket.
In addition, the following fields in the rtems_bsdnet_ifconfig
are of interest.
