The rtems_timer_initiate_server directive is used to
allocate and start the execution of the Timer Server task. The
application can specify both the stack size and attributes of the
Timer Server. The Timer Server executes at a priority higher than
any application task and thus the user can expect to be preempted
as the result of executing the rtems_timer_initiate_server
directive.
