rtems_status_code rtems_clock_get_seconds_since_epoch( rtems_interval *the_interval );
RTEMS_SUCCESSFUL - current time obtained successfully
RTEMS_NOT_DEFINED - system date and time is not set
RTEMS_INVALID_ADDRESS - the_interval is NULL
This directive returns the number of seconds since the RTEMS
epoch and the current system date and time. If the date and time
has not been set with a previous call to
rtems_clock_set, then the
RTEMS_NOT_DEFINED status code is returned.
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems_clock_set is required to re-initialize the
system date and time to application specific specifications.
