rtems_status_code rtems_clock_get_tod( rtems_time_of_day *time_buffer );
RTEMS_SUCCESSFUL - current time obtained successfully
RTEMS_NOT_DEFINED - system date and time is not set
RTEMS_INVALID_ADDRESS - time_buffer is NULL
This directive obtains the system date and time. If the date and time
has not been set with a previous call to
rtems_clock_set, then the
RTEMS_NOT_DEFINED status code is returned.
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems_clock_set is required to re-initialize the
system date and time to application specific specifications.
