BSP and Device Driver Development Guide
The RTEMS configuration table contains the maximum number of objects RTEMS can handle during the application (e.g. maximum number of tasks, semaphores, etc.). It's used to allocate the size for the RTEMS inner data structures.
The RTEMS configuration table is application dependent, which means that
one has to provide one per application. It is usually defined by defining
macros and including the header file <rtems/confdefs.h>
. In simple
applications such as the tests provided with RTEMS, it is commonly found
in the main module of the application. For more complex applications,
it may be in a file by itself.
The header file <rtems/confdefs.h>
defines a constant table
named Configuration
. With RTEMS 4.8 and older, it was accepted
practice for the BSP to copy this table into a modifiable copy named
BSP_Configuration
. This copy of the table was modified to define
the base address of the RTEMS Executive Workspace as well as to reflect
any BSP and device driver requirements not automatically handled by the
application. In 4.9 and newer, we have eliminated the BSP copies of the
configuration tables and are making efforts to make the configuration
information generated by <rtems/confdefs.h>
constant and read only.
For more information on the RTEMS Configuration Table, refer to the RTEMS Application C User's Guide.
