BSP and Device Driver Development Guide
The file bsp_specs defines the start files and libraries
that are always used with this BSP. The format of this file
is admittedly cryptic and this document will make no attempt
to explain it completely. Below is the bsp_specs
file from the PowerPC psim BSP:
%rename endfile old_endfile
%rename startfile old_startfile
%rename link old_link
*startfile:
%{!qrtems: %(old_startfile)} \
%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s start.o%s}}
*link:
%{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -e _start -u __vectors}
*endfile:
%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s ecrtn.o%s}
The first section of this file renames the built-in definition of
some specification variables so they can be augmented without
embedded their original definition. The subsequent sections
specify what behavior is expected when the -qrtems or
-qrtems_debug option is specified.
The *startfile section specifies that the BSP specific file
start.o will be used instead of crt0.o. In addition,
various EABI support files (ecrti.o etc.) will be linked in with
the executable.
The *link section adds some arguments to the linker when it is
invoked by GCC to link an application for this BSP.
The format of this file is specific to the GNU Compiler Suite. The
argument used to override and extend the compiler built-in specifications
is available in all recent GCC versions. The -specs option is
present in all egcs distributions and gcc distributions
starting with version 2.8.0.
