function Clock_Get_Ticks_Since_Boot return RTEMS.Interval;
NONE
This directive returns the number of clock ticks that have elapsed
since the system was booted. This is the historical measure of uptime
in an RTEMS system. The newer service
rtems.clock_get_uptime is another and potentially
more accurate way of obtaining similar information.
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems.clock_set is required to re-initialize the
system date and time to application specific specifications.
This directive simply returns the number of times the dirivective
rtems.clock_tick has been invoked since the
system was booted.
