The memory management manager is ...
The directives provided by the memory management manager are:
mlockall - Lock the Address Space of a Process
munlockall - Unlock the Address Space of a Process
mlock - Lock a Range of the Process Address Space
munlock - Unlock a Range of the Process Address Space
mmap - Map Process Addresses to a Memory Object
munmap - Unmap Previously Mapped Addresses
mprotect - Change Memory Protection
msync - Memory Object Synchronization
shm_open - Open a Shared Memory Object
shm_unlink - Remove a Shared Memory Object
