RTEMS Logo
RTEMS 4.9.1 On-Line Library
Chains Directives
PREV UP NEXT Bookshelf RTEMS C User's Guide
28.4: Directives
  • Chains Initialize Chain With Nodes
  • Chains Initialize Empty
  • Chains Is Null Node ?
  • Chains Head
  • Chains Tail
  • Chains Are Two Nodes Equal ?
  • Chains Is the Chain Empty
  • Chains Is this the First Node on the Chain ?
  • Chains Is this the Last Node on the Chain ?
  • Chains Does this Chain have only One Node ?
  • Chains Is this Node the Chain Head ?
  • Chains Is this Node the Chain Tail ?
  • Chains Extract a Node
  • Chains Get the First Node
  • Chains Insert a Node
  • Chains Append a Node
  • Chains Append a Node (unprotected)
  • Chains Prepend a Node
  • Chains Prepend a Node (unprotected)
  • The section details the Chains directives.
