procedure Object_Set_Name( ID : in RTEMS.ID; Name : in String; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - name looked up successfully
RTEMS.INVALID_ADDRESS - invalid name pointer
RTEMS.INVALID_ID - invalid object id
This service sets the name of id to that specified
by the string located at name.
This directive is strictly local and does not impact task scheduling.
If the object specified by id is of a class that
has a string name, this method will free the existing
name to the RTEMS Workspace and allocate enough memory
from the RTEMS Workspace to make a copy of the string
located at name.
has a thirty-two bit integer style name, then the first
four characters in *name will be used to construct
the name.
