The parameters in this section are used to configure resources
for the RTEMS POSIX API. They are only relevant if the POSIX API
is enabled at configure time using the --enable-posix option.
CONFIGURE_MAXIMUM_POSIX_THREADS is the maximum number of
POSIX API threads that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_MUTEXES is the maximum number of
POSIX API mutexes that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES is the maximum number of
POSIX API condition variables that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_KEYS is the maximum number of
POSIX API keys that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_TIMERS is the maximum number of
POSIX API timers that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS is the maximum number of
POSIX API queued signals that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES is the maximum number of
POSIX API message queues that can be concurrently active.
The default is 0.
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES is the maximum number of
POSIX API semaphores that can be concurrently active.
The default is 0.
