The input/output interface manager provides a well-defined mechanism for accessing device drivers and a structured methodology for organizing device drivers. The directives provided by the I/O manager are:
rtems.io_initialize - Initialize a device driver
rtems.io_register_driver - Register a device driver
rtems.io_unregister_driver - Unregister a device driver
rtems.io_register_name - Register a device name
rtems.io_lookup_name - Look up a device name
rtems.io_open - Open a device
rtems.io_close - Close a device
rtems.io_read - Read from a device
rtems.io_write - Write to a device
rtems.io_control - Special device services
