NOT SUPPORTED FROM Ada BINDING
This directive iterates over all of the existant threads in the
system and invokes routine on each of them. The user should
be careful in accessing the contents of the_thread.
This routine is intended for use in diagnostic utilities and is not intented for routine use in an operational system.
There is NO protection while this routine is called. Thus it is
possible that the_thread could be deleted while this is operating.
By not having protection, the user is free to invoke support routines
from the C Library which require semaphores for data structures.
