NOT SUPPORTED FROM Ada BINDING
NONE
This directive is called after the other Initialization Manager directives have successfully completed. This directive initiates multitasking and performs a context switch to the first user application task and enables interrupts as a side-effect of that context switch.
This directive DOES NOT RETURN to the caller until the
rtems.shutdown_executive is invoked.
This directive causes all nodes in the system to verify that certain configuration parameters are the same as those of the local node. If an inconsistency is detected, then a fatal error is generated.
