The clock facilities of the clock manager operate upon calendar time. These directives utilize the following date and time record for the native time and date format:
type Time_Of_Day is
record
Year : RTEMS.Unsigned32; -- year, A.D.
Month : RTEMS.Unsigned32; -- month, 1 .. 12
Day : RTEMS.Unsigned32; -- day, 1 .. 31
Hour : RTEMS.Unsigned32; -- hour, 0 .. 23
Minute : RTEMS.Unsigned32; -- minute, 0 .. 59
Second : RTEMS.Unsigned32; -- second, 0 .. 59
Ticks : RTEMS.Unsigned32; -- elapsed ticks between seconds
end record;
The native date and time format is the only format
supported when setting the system date and time using the
rtems.clock_get directive. Some applications
expect to operate on a "UNIX-style" date and time data structure. The
rtems.clock_get directive can optionally return
the current date and time in the
following record:
type Clock_Time_Value is
record
Seconds : Unsigned32;
Microseconds : Unsigned32;
end record;
The seconds field in this record is the number of seconds since the POSIX epoch of January 1, 1970 but will never be prior to the RTEMS epoch of January 1, 1988.
