#include <signal.h> int sigprocmask( int how, const sigset_t *set, sigset_t *oset );
This function is used to alter the set of currently blocked signals
on a process wide basis. A blocked signal will not be received by the
process. The behavior of this function is dependent on the value of
how which may be one of the following:
SIG_BLOCK
set and
those signals currently blocked.
SIG_UNBLOCK
set are removed from the currently
blocked set.
SIG_SETMASK
set.
If oset is not NULL, then the set of blocked signals
prior to this call is returned in oset.
It is not an error to unblock a signal which is not blocked.
