RTEMS Logo
RTEMS 4.9.0 On-Line Library
ARM Specific Information
prev UP NEXT Bookshelf RTEMS CPU Architecture Supplement
Chapter 2: ARM Specific Information
  • ARM Specific Information CPU Model Dependent Features
  • ARM Specific Information Calling Conventions
  • ARM Specific Information Memory Model
  • ARM Specific Information Interrupt Processing
  • ARM Specific Information Default Fatal Error Processing
  • ARM Specific Information Board Support Packages
  • This chapter discusses the ARM architecture dependencies in this port of RTEMS. The ARM family has a wide variety of implementations by a wide range of vendors. Consequently, there are many, many CPU models within it.
    Architecture Documents
    For information on the ARM architecture, refer to the following documents available from Arm, Limited (`http//www.arm.com/'). There does not appear to be an electronic version of a manual on the architecture in general on that site. The following book is a good resource:
