RTEMS Logo
RTEMS 4.9.0 On-Line Library
Chains Creating a Chain
PREV UP NEXT Bookshelf RTEMS C User's Guide
28.3.2: Creating a Chain
To create a chain you need to declare a chain control then add nodes to the control. Consider a user structure and chain control:
typedef struct foo
  rtems_chain_node node;
  uint8_t char*    data;
} foo;
rtems_chain_control chain;
Add nodes with the following code:
rtems_chain_initialize_empty (&chain);
for (i = 0; i < count; i++)
  foo* bar = malloc (sizeof (foo));
  if (!foo)
    return -1;
  bar->data = malloc (size);
  rtems_chain_append (&chain, &bar->node);
The chain is initialized and the nodes allocated and appended to the chain. This is an example of a pool of buffers.
