RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.16: OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
CALLING SEQUENCE:
rtems_status_code rtems_object_get_class_information(
  uint32_t                            the_api,
  uint32_t                            the_class,
  rtems_object_api_class_information *info
DIRECTIVE STATUS CODES
RTEMS_SUCCESSFUL - information obtained successfully
RTEMS_INVALID_ADDRESS - info is NULL
RTEMS_INVALID_NUMBER - invalid api or the_class
If successful, the structure located at info will be filled in with information about the specified api/the_class pairing.
DESCRIPTION:
This service returns information about the object class indicated by the specified api and the_class. This structure is defined as follows:
typedef struct {
  rtems_id  minimum_id;
  rtems_id  maximum_id;
  uint32_t  maximum;
  bool      auto_extend;
  uint32_t  unallocated;
} rtems_object_api_class_information;
NOTES:
This directive is strictly local and does not impact task scheduling.
