RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services OBJECT_GET_API_NAME - Obtain API Name
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.14: OBJECT_GET_API_NAME - Obtain API Name
CALLING SEQUENCE:
const char *rtems_object_get_api_name(
  uint32_t api
DIRECTIVE STATUS CODES
If api is not valid, the string "BAD API" is returned.
If successful, this service returns a pointer to a string containing the name of the specified api.
DESCRIPTION:
This service returns the name of the specified api.
NOTES:
This directive is strictly local and does not impact task scheduling.
The string returned is from constant space. Do not modify or free it.
