RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.11: OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
CALLING SEQUENCE:
uint32_t rtems_object_id_api_maximum(void);
DIRECTIVE STATUS CODES
Returns the maximum valid for the API portion of an object Id.
DESCRIPTION:
This service returns the maximum valid for the API portion of an object Id.
NOTES:
This directive is strictly local and does not impact task scheduling.
