RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services BUILD_ID - Build Object Id From Components
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.9: BUILD_ID - Build Object Id From Components
CALLING SEQUENCE:
rtems_id rtems_build_id(
  uint32_t the_api,
  uint32_t the_class,
  uint32_t the_node,
  uint32_t the_index
DIRECTIVE STATUS CODES
Returns an object Id constructed from the provided arguments.
DESCRIPTION:
This service constructs an object Id from the provided the_api, the_class, the_node, and the_index.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the arguments provided or the Object id returned.
