RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services OBJECT_ID_GET_NODE - Obtain Node from Id
PREV UP NEXT Bookshelf RTEMS C User's Guide
27.4.7: OBJECT_ID_GET_NODE - Obtain Node from Id
CALLING SEQUENCE:
uint32_t rtems_object_id_get_node(
  rtems_id id
DIRECTIVE STATUS CODES
Returns the node portion of the object Id.
DESCRIPTION:
This directive returns the node portion of the provided object id.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id provided.
