RTEMS Logo
RTEMS 4.9.0 On-Line Library
Object Services Printing an Object Id
27.3.2: Printing an Object Id
RTEMS also provides services to associate the API and Class portions of an Object Id with strings. This allows the application developer to provide more information about an object in diagnostic messages.
In the following C language example, an Id is decomposed into its constituent parts and "pretty-printed."
void prettyPrintObjectId(rtems_id id)
  uint32_t tmpAPI, tmpClass;
  tmpAPI   = rtems_object_id_get_api(id),
  tmpClass = rtems_object_id_get_class(id),
  printf(
    "API=%s Class=%s Node=%d Index=%d\n",
    rtems_object_get_api_name(tmpAPI),
    rtems_object_get_api_class_name(tmpAPI, tmpClass),
    rtems_object_id_get_node(id),
    rtems_object_id_get_index(id)
