RTEMS Logo
RTEMS 4.9.0 On-Line Library
CPU Usage Statistics Report CPU Usage Statistics
26.3.1: Report CPU Usage Statistics
The application may dynamically report the CPU usage for every task in the system by calling the rtems.cpu_usage_report routine. This routine prints a table with the following information per task:
The following is an example of the report generated:
CPU Usage by thread
   ID        NAME        TICKS    PERCENT
0x04010001   IDLE           0     0.000
0x08010002   TA1         1203     0.748
0x08010003   TA2          203     0.126
0x08010004   TA3          202     0.126
Ticks since last reset = 1600
Total Units = 1608
Notice that the "Total Units" is greater than the ticks per reset. This is an artifact of the way in which RTEMS keeps track of CPU usage. When a task is context switched into the CPU, the number of clock ticks it has executed is incremented. While the task is executing, this number is incremented on each clock tick. Otherwise, if a task begins and completes execution between successive clock ticks, there would be no way to tell that it executed at all.
Another thing to keep in mind when looking at idle time, is that many systems -- especially during debug -- have a task providing some type of debug interface. It is usually fine to think of the total idle time as being the sum of the IDLE task and a debug task that will not be included in a production build of an application.
