The CPU usage statistics manager is an RTEMS support component that provides a convenient way to manipulate the CPU usage information associated with each task The routines provided by the CPU usage statistics manager are:
rtems.cpu_usage_report - Report CPU Usage Statistics
rtems.cpu_usage_reset - Reset CPU Usage Statistics
