The Multiprocessor Configuration Table contains
information needed when using RTEMS in a multiprocessor
configuration. Many of the details associated with configuring
a multiprocessor system are dependent on the multiprocessor
communications layer provided by the user. The address of the
Multiprocessor Configuration Table should be placed in the
User_multiprocessing_table entry in the primary Configuration
Table. Further details regarding many of the entries in the
Multiprocessor Configuration Table will be provided in the
Multiprocessing chapter.
When using the rtems/confdefs.h mechanism for configuring
an RTEMS application, the macro CONFIGURE_MP_APPLICATION must
be defined to automatically generate the Multiprocessor Configuration Table.
If CONFIGURE_MP_APPLICATION, is not defined, then a NULL pointer
is configured as the address of this table.
The format of the Multiprocessor Configuration Table is defined in the following C structure:
typedef struct {
uint32_t node;
uint32_t maximum_nodes;
uint32_t maximum_global_objects;
uint32_t maximum_proxies;
uint32_t extra_mpci_receive_server_stack;
rtems_mpci_table *User_mpci_table;
} rtems_multiprocessing_table;
an RTEMS application, the value for this field corresponds
to the setting of the macro CONFIGURE_MP_NODE_NUMBER.
If not defined by the application, then the CONFIGURE_MP_NODE_NUMBER
macro defaults to the value of the NODE_NUMBER macro which is
set on the compiler command line by the RTEMS Multiprocessing Test Suites.
to the setting of the macro CONFIGURE_MP_MAXIMUM_NODES.
If not defined by the application, then the CONFIGURE_MP_MAXIMUM_NODES
macro defaults to the value 2.
to the setting of the macro CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS.
CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS macro defaults to the value 32.
to the setting of the macro CONFIGURE_MP_MAXIMUM_PROXIES.
If not defined by the application, then the CONFIGURE_MP_MAXIMUM_PROXIES
to the setting of the macro CONFIGURE_MP_MPCI_TABLE_POINTER.
CONFIGURE_MP_MPCI_TABLE_POINTER macro defaults to the
address of the table named MPCI_table.
