The rtems.timer_cancel directive is used to halt the
specified timer. Once canceled, the timer service routine will
not fire unless the timer is reinitiated. The timer can be
reinitiated using the rtems.timer_reset,
rtems.timer_fire_after, and
rtems.timer_fire_when directives.
