procedure Clock_Get_TOD_Timeval ( Time : in RTEMS.Timeval; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - current time obtained successfully
RTEMS.NOT_DEFINED - system date and time is not set
RTEMS.INVALID_ADDRESS - time is NULL
This directive obtains the system date and time in POSIX
struct timeval format. If the date and time
has not been set with a previous call to
rtems.clock_set, then the
RTEMS.NOT_DEFINED status code is returned.
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems.clock_set is required to re-initialize the
system date and time to application specific specifications.
