RTEMS CPU Architecture Supplement
The ARM architecture supports two external interrupts - IRQ and FIQ. FIQ has a higher priority than IRQ, and has its own version of register R8 - R14, however RTEMS does not take advantage of them. Both interrupts are enabled through the CPSR.
The RTEMS interrupt level mapping scheme for the AEM is not a numeric level as on most RTEMS ports. It is a bit mapping that corresponds the enable bits's postions in the CPSR:
Copyright © 1988-2007OAR Corporation
