rtems_status_code rtems_rate_monotonic_get_status( rtems_id id, rtems_rate_monotonic_period_status *status );
RTEMS_SUCCESSFUL
- period initiated successfully
RTEMS_INVALID_ID
- invalid rate monotonic period id
RTEMS_INVALID_ADDRESS
- invalid address of status
This directive returns status information associated with the rate monotonic period id in the following data structure:
typedef struct { rtems_id owner; rtems_rate_monotonic_period_states state; #ifdef RTEMS_ENABLE_NANOSECOND_RATE_MONOTONIC_STATISTICS struct timespec since_last_period; #else uint32_t ticks_since_last_period; #endif #ifdef RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS struct timespec executed_since_last_period; #else uint32_t ticks_executed_since_last_period; #endif } rtems_rate_monotonic_period_status;
A configure time option can be used to select whether the time information is
given in ticks or seconds and nanoseconds. The default is seconds and
nanoseconds. If the period's state is RATE_MONOTONIC_INACTIVE
, both
time values will be set to 0. Otherwise, both time values will contain
time information since the last invocation of the
directive. More
specifically, the (ticks_)since_last_period value contains the elapsed time
which has occurred since the last invocation of the
directive and the
(ticks_)executed_since_last_period contains how much processor time the
owning task has consumed since the invocation of the
directive.
This directive will not cause the running task to be preempted.
Copyright © 1988-2007OAR Corporation
