void rtems_interrupt_enable( rtems_interrupt_level level );
NONE
This directive enables maskable interrupts to the level
which was returned by a previous call to
rtems_interrupt_disable
Immediately prior to invoking this directive, maskable interrupts should
be disabled by a call to rtems_interrupt_disable
and will be enabled when this directive returns to the caller.
This directive will not cause the calling task to be preempted.
Copyright © 1988-2007OAR Corporation
