BSP and Device Driver Development Guide
The checkRealTime
routine returns the number of seconds
difference between the RTC TOD and the current RTEMS TOD.
int checkRealTime( void ) { if no RTCs are present return -1 obtain the RTEMS TOD using rtems_clock_get get the TOD from the preferred RTC using the deviceGetTime routine convert the RTEMS TOD to seconds convert the RTC TOD to seconds return the RTEMS TOD in seconds - RTC TOD in seconds }
Copyright © 1988-2007OAR Corporation
